KingDazza
Hi,
Any ideas why the top PCIe lane would run my HD7970 DD Black Edition slowly - its rated at PCIe x16? If I put the card into the 2nd PCIe x8 or the third PCIe x16/x8, then full performance is delivered. I don't see it being driver related as I've tried this out on two separatete win 7 installs with same result. Also if card is in the problem lane closest to the CPU, then I sometimes get slow EFI screen navigation.
Does this lane need more power via the 4pin EZ mobo plug?
Is it normal for a mobo just to prefer certain lanes for single GPU set ups, when there is a choice of 4 PCIe lanes?
All is at stock and with a 3820. No stability issues whatsoever. Just hampered gpu performance in top lane closest CPU.
Any help appreciated, cheers!
