XMS said:Hi Chaos,
I take it that you are running @ stock at the moment?
I would try going into your bios and using optimised defaults to see if that helps.
Have you got any other devices installed in your machine (sound cards etc)? It may be worth removing any non-essentials to see if that helps.
name='llwyd' said:have you tried stipping everything out other than the essentials and just one hdd and one stick of ram?
