Asus Maximus VII VCore Q
Bented
Hi,
I've gone for an OC of 4.6Ghz on my 4790k processor.
I was wondering if there is a way to set the Vcore required to get it to step down the Vcore as the processor frequency is lowered while it's not been tasked? e.g Frequency goes from 4.6Ghz to 800Mhz and this will change all the time while idling.
On my previous Maximus board there was a offset feature where you'd set the vcore to auto... then you'd max out the CPU to find the max Vcore the mobo would give the chip and then use +/- to adjust it to near what was needed.
is there a way to do that on the Maximus VII or a more simplified way to get that done?
Thanks.
Thanks
You have to set the vcore voltage to "offset", you currently have set it as fixed voltage
