Which is correct, I had a quick look but I actually couldn't find anything on that particular part of the board apart from th cpu fan header and optional header :/
The one near the PCI slot is a 1394 header which is not listed in the Motherboard manual your right. It looks very similar to an internal USB 2 header if you were not paying enough attention
My Rampage 5 Extreme has two near the thunderbolt port which arnt listed in the manual either
Well the OC Panel uses a 1394 in conjunction with a internal USB 2 header which are placed next to each other on the Motherboard. Called "ROG_EXT" The OC panel and the Base station cable (which are identical) fit over both headers.
The OC Panel that Tom loves so much
It cant be that though, the base station (unlike the OC Panel) uses both a ROG connector and a 7 pin AAFP. The AAFP looks different to the other pin header and I can see it labled on the bottom left of the Motherboard
