MicroAlex
Hey mates,
Having an interesting issue with my rig that results in a AE error code.
Here is the story...
I finally decided to build myself a desktop as things in my life have changed and I have a chance to move away from bulky gaming laptops as my main productivity device.
So, recently I got my fresh stock of parts for the build.
So, after connecting my drives I have installed a fresh copy of Win7 on to the SSD. Installed the drivers, software... whatever I will need to get this PC in to a productive state.
After updates, etc were installed - the machine was functioning well. Went to Computer Management and added my WD drive as a drive D (was expecting the HDD to show up automatically but I suspect a conflict maybe occurred between the HDD and Corsairs Surviver USB key that was initialised as a Drive D in the system on boot). Once that was done I could access my WD drive for the naughty stuff
...But then I have decided to move the cables around in the case, replace the stock Asus SATA cable with my older solid black ones, and also to unplug my 2.5 WD Black drive for the time being.
Once the cables were tidy and everything was at a state that I felt was good enough until I decide on the last components - I have went to power up my baby and see if all is good. In result I was greeted by a BIOS screen every time I would turn on the machine. A few restarts and hard resets on the board later I have checked the error code LED lights and they have stated code "AE".
Since "AE" code means "Legacy Boot Event" I kinda got confused, but then I have also noticed that before it goes to "AE" it shows "A2". Suspecting the problem might be with the drive connection this is what I have done so far - logical and desperate solutions.
No result! But, then I decided to reconnect my WD Black in to the chain and BAAAM! It's alive!!! The board posts, boots and functions as from the start. Removing the SATA data and power cable from the WD drive just for LOL's later on resulted in the same error code.
So my question is - WHY?!
Why is this board acting up this way? Can it possibly be something to do with the fact that the WD drive was added through the Computer Management menu as a drive D?
Had a similar problem once with RAM. Alienware laptop would not boot after some BIOS tweaks on my 16GB kit of 2133mhz memory, but had no problems if I would add another 8GB to that. Loading optimal defaults or flashing bios and battery BIOS reset had no effect. This is not relevant I am sure, but wanted to share
Hope someone can shine some light on this situation. And sorry for a long description.
Thanks for your time.
- i7-4790k
- Windows 7 Pro
- Asus Impact II
- Corsair AX860i
- Corsair 380T
- Samsung EVO 840 240GB (salvaged from my laptop)
- WD Black 2.5 inch 750GB (salvaged from my laptop)
- NO GPU (running onboard for now, deciding at the moment)
- Spare DDR3 stick of 1600 4GB RAM from my magic cupboard (deciding on the RAM as well).
- Reseated SATA connectors on both ends
- Reseated SATA power connectors on both ends
- Unplugged fans from the same SATA power cable
- Go back to default Asus SATA data cable
- CMOS RESET
- Loaded Optimal Settings in BIOS...
