FalconFX said:hello there...
Just one short question. Is the ASUS A8N-SLI Deluxe able to use SATA II Hard drives ? I would say yes, but i cant find any hints in the manual or elsewhere.
Thanks
HEXUS|Ramedge said:not to sure if it is or not - but i have a first generation one, i updated the bios before i got my SATA II drive and the bios did recognise it as a SATA II device - weather or not it works at the speed that SATA II is meant to work at is another story.
But yes - SATA II drives do work on that mobo
name='FragTek' said:DL a program called HD Tach and do a quick test, that will tell you straight away whether or not it's working at SATA II speeds.
HEXUS|Ramedge said:cool - that sounds quite usful![]()
will download it and report back if i do get SATA II speeds![]()
HEXUS|Ramedge said:yeh deffinetly not taking full advantage there. but then raptors arnt SATA II are they ?
so that would explain it.
I am running out of storage- need to RMA my b0rked Seagoat 200gb SATA drive asap.
kempez815 said:My Hitachi's are SATA II and this is what I get in RAID 0![]()
name='FragTek' said:10k is teh pwnage... SATAII Raptors, if they come about, will be the perfect HD's.
FragTek said:SATA II is all about high burst... Comparitively between my setup and kemps setup, the Raptors are twice as fast in the random access department and have a higher average read speed.
