Hi guys,
got a bit of a problem with my 8800GTS using the dvi connector on the card and my samsum 940BW 19" Widescreen! basicly no matter how i set the resolution the screen always seems out of focus. its as if the screen is defaulting to a standard (non widescreen) resolution even though its recieving the correct 1440x900 widescreen signel.
i'm using the latest drives for both the screen and from nvidia, and i have also tested the screen on an ATI Radion Saphire 9550 using the dvi socket, and everything is fine?
anyone got any ideas whats causing this?
also fire any more questions at me if you need any more info about my setup. i've probally missed something out that you need to know.
Thanks in advance
-kenzie_01-
Thanks in advance
-kenzie_01-
