High everyone.
Running two 560 ti's together, they are hell close to eachother and after installing case fans on the side panel I have them at idle temps:
gpu 1 - 33deg
gpu 2 - 26deg
They are overclocked through msi Afterburner to 950 core clock, 1900 shader clock, and I haven't increased the memory clock at all.
Core voltage was left at 1025 stock.
Didn't want to raise the core voltage due to more heat. Gpu 1 is getting up to 83 degrees in metro 2033 at high settings with physx turned off.
I am new to overclocking graphics cards and even though I have had what seems to be stable performance. ( I am not running furmark, Metro 2033 is good enough to get a graphics card angry imo, not sure if I want to use furmark and try and break my gpu's under ultra stress tests)
So I was wondering what I should set the values at regarding core voltage to clock/shader ratio and what to do with the memory clock?
The overclocks are synchronised through Afterburner. Seems to be fine at my current overclock. If i was to go any higher it would probs be smarter to do them independantly? to see if they can both be brought up further in the specific fields.
950 is giving me good performance though in Metro 2033, solid 60 fps most of the time. I don't know if it is worth overclocking up to 1000mhz and there is the heat issue also. But perhaps the mem clock should be higher? does that create heat also and will I need to then up the core voltage?
What can you guys recommend,
Thanks for reading,
FACECHUNK.
gpu 1 - 33deg
gpu 2 - 26deg
Thanks for reading,
FACECHUNK.
