Arhh! :(
Toxcity
My pump is makeing a weird noise! :(
Like bits are going though it.. clicky clicky.. But not all the time... they will be like pauses between for about 10 seconds.. But there is nothing in the water.. so I don't thinks it taht. :(
Any ideas?
name='Kempez' said:
Mine does the same. I have a feeling theres some water stuck in the loop but I cba to faff about getting it tou ;)
So I guess its okay.. :)
Come to mention it, the sound does sound like water going quickly though a small hole..
My pumps do that some times.. maye you got a few bubbles still in the loop as every so often.. say... once per 4 hours or so, my pumps make a swooshing sound for 2seconds
shake the rad, tilt it left and right, up and down. i would do this with the comp off thou(jumping the psu)
or depedning on which rad you are using, take it out of the case... and unscrew the screw which is fitted on the bottom end opposite side of the connectors (facing up of course), to let any bubbles trapped free.
