an athlon 64 3000+ runs at 2GHz but is it the equivilant of 3GHz? cos i am confused is it 2GHz of raw power or does the fact it has an efficnent core make it the equivilant of 3GHz?
an athlon 64 3000+ runs at 2GHz but is it the equivilant of 3GHz? cos i am confused is it [B']2GHz of raw power or does the fact it has an efficnent core make it the equivilant of 3GHz?[/B]
ionicle are you not understanding anything?? yes you have a 3ghz IF COMPARING TO AN INTEL but why would you want to do that. once you get a small piece of PC knowledge you will stop comparing amd to intel and vice versa and you will take them as what they are.
