D Drazic Guest Jun 28, 2006 #1 Anyone know what is the safest sub zero temps the AquaXtreme 50Z pump can handle? It's the blue one i got.
M maverik-sg1 New member Jun 28, 2006 #2 Used mine at -10 water temps - probs go lower but the coolant mix was not high enough and the fluid went slushy and compacted in the pump causing it to stall. The AQZ is the best pump to use in this application. Mav
D Drazic Guest Jun 29, 2006 #3 Mav cheers dude. i got possibly a silly ideal planed not sure exactly. Gald to know she'll cope with the cold
P Phil Stanbridge New member Jun 29, 2006 #4 Make sure the tubing is up to the job too - you'll probably find the tubing freezes before the pump.
D Drazic Guest Jun 29, 2006 #5 Got a mixture to use as the coolent, not fully sure on temps yet, got to sit and work it out and see what it wil ldo to my evap temps
