aquamark
HARRY
hi doods ive just been running some benches with aquamark3 and i can turn ht on does anyone know how
Its usually on by default,unless am3 crashes and asks if you want to reset a/v configuration,then go into options and click the bottom option to toggle on/off.
just looking @ the options screen now and it says at the bottom that its turned of and it wont lett me turn it on
Normally you just click it,is h-t disabled in bios or anywhere else ?,does cpu-z show h-t enabled ? or re-install AM3.
its on in bios but when i look in sandra its not and it says os does not support hyperthreading extremely strange i think
