I have been aproched and asked to figure a way to incorperate this into my cases.
http://www.coolitsystems.com/
Has anyone used one yet?
name='ai_01' said:if im right they use a pelt to chill the water.
name='markkleb' said:Mr Popo please show me the links that say it dosent work that good. (before I design it in my case)
name='markkleb' said:I am gonna mod their system, first I am gonna use a 120mm fan (they use a 90mm) and second I am gonna take the pump away from the front of the rad (blocks air)
name='Ares210' said:Lol so basically there giving this to you and your going to mod the crap out of it?![]()
name='Mr. Popo' said:http://www.extrememhz.com/freezone-p3.shtml
In here you can see the freezone (the better one), and it's not better than a good heatsink.
http://www.hardcoreware.net/reviews/review-327-4.htm
The same.
The same.
name='Ares210' said:Are you serious? Those temps are pretty good and when the chips oc'd it only rose a degree unlike the heatsink where i rose several. Those temps are much better than a good heatsink and probably quieter.
name='Mr. Popo' said:Don't start assuming things, look at it vs stock.
Also, when you OC the difference is getting smaller (Can't do high load).
