I was thinking of using a 200mm radiator in my 600t but wasnt sure the 200mm fans out there were up to the task of properly cooling it to its fullest potential so would something like a 200mm to 120/140 with better static pressure make a diffrence? or perhaps even custom fab an adapter for 2 120mm fans to 200mm?
Would a push pull 200mm fan make up for the low static pressure by nature of larger fans?
when using an adapter does air not flow over all the fins equally? i envision some dead spots on the radiator when using an adapter but if anyone knows of reviews that say otherwise i appreciate your experience and advice.
