Any experience with fan/rad/fan/rad/fan setup?
TBash
Like the title says does anyone have any experience using a setup where a series of fans and rads go in a line my only thought after doing some research is you would obviously need some high static pressure fans to make it worthwhile. I want to have a setup like this do to space constraints but i can see linking all of them together being the only problem.
Perfect just what i wanted to know only question im left with is would higher static pressure fans make a difference? it seems though that making the fans work harder to push through more radiators is a loss all around im going to have to rethink my radiator idea thank you again.
