Antec TrueQuiet Pro 120
SEBAR
Has anyone used the TrueQuiet Pro 120 fans? If so, what is your opinion of these fans? I am considering getting these fans but I am hesitant. I want good quality fans that are quiet.
Thanks
If you want quiet 120mm fans that shift a good amount of air the Noctua Focus Flow fans are awesome. The Akasa Apache and the Bitfenix Spectre Pro's are also good. Be quiet and Cougar also make good fans.
Those are all very good fans. I may be ordering somthing soon because I went back to the local computer store and they where all sold out of the TrueQuiet Pro 120 fans so I will need to order soming anyway. I was interested in the Antec fans because I could pick them up locally. I am leaning to the Bitfenix fans, they look nice.
TBH anything antec has to offer is shite! though you be finding that out asap as you purchased it. If you want good fans the Noctuas and the SilenX is good(im using silenX 24mnth)
If you want those differnet glowing fans then go to enermax
I never considered the SilenX fans, next time I am at the store I will check them out.
Thanks
Thanks
Have 18 of them running soon. Had 6 running the last year and no probelms. Hear the noctuas and these are queiter and move more air. Dunno if they have same stqatic pressure but they r good anyways
I use the TrueQuiet Pro 140mm to extract air from the top of my case, Works very well.
It is very quiet and the performance is great!
I ended up going with TB Silence. The Antec TrueQuiet fans must be pretty popular because they are always sold out in the local stores.
