Antec Kuhler 920
sCuBaSUN
Hi, After recently giving my pc a good clean-out, I noticed 2 of the screws holding my Kuhler 920 to my case won't tighten anymore. Is there anyway to re-thread the Radiator or any other way to make it more secure?
If you have rounded out the holes then you have lost metal. Thus, recutting the holes with a tap won't work as you don't have the metal you need to cut the thread again.
You could tap it with a bigger tap and then use a bigger screw but you'd need to be very careful.
I'm leaning towards soldering 6-32 thread to the Rad and using nuts. Think it'll be safer and pretty easy to do.
I agree this is your solution. I have the same CPU cooler. I would tap some M4 threads, and call it a day.
