Antec 1200 Setup (Old)
moogle
Thought I might post some pics of my rig when I had my 1200 (May-Sept). After that I've been without a case for a while but it's always nice to see other peoples pics of their rigs so here's mine.
picture.php
picture.php
picture.php
Currently the PC is looking like this... (My room's a bit crap, can't do much about it so I spend the money on my PC instead :p)
Ugly I know but soon to be housed in a TJ07. I've got all bits and bobs for watercooling it (bar the GPU block) and I don't want to use it now while it's not in a case. Want to keep it all still new until they go into their proper home :D
Hope it isn't all too showy offy. I always like looking at other peoples rigs so I hope you all like to do that too.
:wavey:
Isn't too showoffy :) In fact, most people probably wouldn't even post their rigs if it had its guts on cardboard :D
The 1200 looks quite good, if you use the same skill in your TJ-07 it should turn out nice. What are you going to put in, watercooling wise?
Gotta love the cardbox setup, ghetto mod ftw.
name='shaka' said:
you definitely need a case mate once you get it show some pics ;)
I know I've been waiting ages. Pics will be shown and I'll probably do a build log as well :D
Thanks :D
I had this ghetto cardboard box setup when I was getting the 1200 because they delayed it so much!
Watercooling wise I have a Swiftech Apogee GTZ, Swiftech MCW-NBMAX (North Bridge cooler that will fit on the MF2), 2 DDC 18w pumps with Alphacool tops (might swap those), Thermochill PA120.3 and PA120.2 (wanting some good overclocking with some silence) and I think I'm going to use 7/16" tubing!
Just gotta select a GTX280 block then I'm finished.
name='HafMaster' said:
Sounds great so far. Bet you are looking forward to getting that case.
Yeah I can't. Been waiting ages getting bit by bit each month :haha:
Just want to settle it down and have my system all set up so I don't got to fiddle with it until the next upgrade :D
