Anonfriend
Anonfriend
Can anyone spare some time to assist a newbie to oveclocking.
I have been building PC's for 15 years but have never overclocked before.
I have on recommendation just bought the following:
AMD Athlon 64 X2 3800+ Socket 939, Manchester, 2x 2.0GHz, 1MB Cache.
ASUS A8N-E NF4 Ultra, S939, PCI-E (x16), DDR 400, SATA II, SATA/IDE RAID, ATX
HFT-CLP0114 Thermaltake CL-P0114 Big Typhoon heatpipe CPU Cooler
Arctic Silver 5 Thermal Compound for CPU and Chipset Coolers
1 GB (2 x 512MB) Corsair XMS, DDR PC3200 (400), 184 Pin, Non-ECC Unbuffered, CAS 2-3-3-6
Thanks,
Matt
Hey mate!
Welcome to the forums :wavey:
Whats up with the rig?
Make a new thread in the AMD section and we'll see what we can do to help :D
I have not yet even received the bits in the mail, expecting them on wednesday. Easy enough to put together for me although I have no idea how to max the performance from what I have bought.
I am not interested in the graphics side of things, even though i got a 256MB card to keep my speed up. I am after pure processing speed and gather that I can get 4800 from the chip i bought.
Anyone got any specific advice?
firstly i can see your psu stopping you from overclocking very far, which seems a sham elooking at the rest of your comp :(
Psu
Why would I need more than 480W?
I believe a 30% tolerance is the recommended level and I thought the AMD X2's were highly efficient when it comes to Wattage.
If you have any specific recommendations I would be very interested to hear them.
Thanks.
Depends on what PSU you use tbh.
If it's a good PSU then 480 may be anough. Don't believe wattage calculators as they are naff
I would not say that an XClio will be stable.
For instance: when we put an Ebuyer 600w PSU under load it was meant to be able to cope with:
I beleive what they are refering to is that fact that it is not a well known powersupply and is therefore of questionable quality, and this can cause your overclock to be lower.
Not just that - it can cause total system instability. It may work now but whether it is still stable in two weeks time is another thing.
IIRC XClio actually make some decent PSUs. Obviously not amazing one's like PCP&C and Silverstone, but decent budget PSUs nonetheless. You'd have to look over at Hard Forum though. I don't have time to check myself atm.
