Does anyone know if it's possible to fit an 80mm fan in the side of these things? I'm worried about the airflow in it and my CPU temps after running a day are nearing 53 degrees
If I can fit an 80mm fan in the side will this help reduce temps or will it just create dead spots in the case which is never a good thing?
Cheers
Boardy
Cheers
Boardy
