Alright, so, I have a particular conceptual project where we're supposed to come up with a computer setup for a logging business in Manitoba...
It's a "desktop", but it may be used indoors or outdoors, 24/7, has to survive considerable cold (say -40 degrees C) as well as considerable heat (say +30 degrees C)... It also has to be able to brave the elements (ie, rain, snow, wind...), and it will also likely be placed in a logging environment that will have plenty of woodchips and sawdust in the area, as well as diesel fumes from the machinery... (yes, it's not the most detailed of projects, so there's some wiggle room)
Now, we're thinking of sealing the unit and having something along the lines of a single "fan-controller" (or such) responsible for the ventilation of the entire unit...
Are there any market units available that will filter whatever air is coming into it (for saw dust, chips, etc...?), as well as possibly heat (or cool? but unlikely to be necessary) the air being circulated? Something compact would be best... (Would I also need a separate exhaust, or will the unit have one?)
If anyone has any better ideas btw, feel free... ^^
(this is also sort of very last minute, could use a response ASAP if possible
