I was under the impression that vsync should match your card's frame buffer to the refresh rate of your monitor. With an Nvidia card that seems to work. You have a 60Hz monitror, vsync caps you to 60fps, you have a 144Hz monitor, vsync caps you to 144fps (if your card can stay above that). I recently bought an RX480 and it seems that vsync caps you to 60fps no matter what your monitor is set to. Being new to AMD cards, am I doing something wrong?
