AMD vga drivers making problems with 2 screens?
athlon64
So i have a dell u2412m as i primary monitor, u2311h as a secondary, i have a radeon 7850 and 13.2 beta 3 drivers. I leave my pc on over night, in the morning my wallpaper is extended over 2 displays (there should be 2 different wallpapers on both displays" And when i try to set up my wallpapers windows doesn"t give me the ability to "set wallpaper for monitor 1 / 2 " it just gives an option "set as desktop background". What is the problem here? Restart is the only thing that helpes.
nvidia control panel used to let you set different papers and spanned desktop then they nerfed it.
when i used to have 2 screens i had it on older nvidia drivers but once nvidia updated the drivers for dx11 and well i blame microsoft with windows 7.. they broke the control panel...
same happend with amds desktop driver..
i would do as yassarikhan786
suggested and get ultramon its the only program i know of that lets you select different papers and actually keeps them there after the monitors/os goes to sleep mode..
You didn"t get the point of my question at all. Dual wallpaper work on windows 8. But when card spends a night in zerocore mode drivers crash beacuse of something. That makes problems. So we are not trying to solve wallpaper problems but to stup drivers from making progblems.
Oh right, you're using Windows 8. You should have said that in the OP :p
I assumed it was Windows 7. You could roll back drivers.
I don"T think it"s gonna help, Zero core seems not to be working right and causing instability. I think i"ll just disable it.
