WYP
News Guru
AMD declares their RX 9070 XT the value king - RTX 5070 Ti delivers less performance/$.
Read more about the Radeon RX 9070 XT's value proposition.
$600 is very good! Well done AMD. As long partner cards are available at that price and they make all attempts to prevent scalping and international gouging, they will sell boatloads of these all over the world. I look forward to the Steam hardware survey shifting over the next few years. Even if FSR 4 is not up to the standards of DLSS 4, I still think they have a winner.
However, $550 for the non-XT? I see they learned nothing from the 7700XT. Unless it's impossible to make appropriate margins on such a cut down chip, the non-XT is going to be nothing more than an ugly promotional tool for the full die. Shame really.
Firstly yeah $600 is awesome. Usually they snuggle up and in this case that would be the $750 5070ti. So $150 less for the same raster is a lot.
Where we differ on opinion though is the 9070. See, the way I look at it is that it is over 20% more performance than the 7900GRE for the same price. That said, AMD do drop prices over time. Clearly they have with the 7800XT and 7700XT to bring them more in line. So yeah, right at launch it will probably make less sense than it will a year in. Me however? well I am fine with that. I know now that I can replace any of my GPUs with more performance for 550. The only one that has cost me less than that was the 6900XT Toxic. The 6800XT Strix was 720 quid and the 6950xt without the block was 630 IIRC. Which tbh I was quite happy to pay, as they were all at least 50% cheaper than the 2080ti they replaced and a fair chunk faster too.
Watched Tom's video earlier. That Sapphire (hope this does not become a reality pun lmfao) is fire. Absolutely gorgeous card. Let's just hope the big coolers don't add too much to the cost.
It's a worse GPU though. They could have made two amazing GPUs. But it's one amazing one and one OK one. That seems pointlessly demoralising for those that wanted to spend less but still get a 16GB card.
That said, the 7700XT is higher up on the list on Steam than the 7800XT...
Yea for a reason. And that reason is price.
You need to ignore the higher card. Then think 550 for the same price as the GRE with 23% higher raster perf.
That 50 can buy you an ssd dude.
Both will perform well. We've all known for quite some time the performance levels AMD were targeting. If people are upset it doesn't perform more than a 7900XT that is on them and not AMD.It's only going to be the value king if it performs well. If it's 7900XT levels of perf then AMD are onto a winner. The real issue is retailers marking the prices up, Places like OCUK who are now known as overchargers UK for a reason which ends up putting people off.
But is it reasonable to cherry pick comparisons? It's difficult to ignore a GPU that's clearly better.
Oh of course. I'd imagine right now that depending on yield the XT will be the more plentiful card. IE only failed XT dies will be 9070s. Meaning cost will be the same.
That's probably why the small price gap. However we all know AMD will reduce those prices in line over time. The 7700XT is higher in the Steam survey than the 7800XT and on launch that made no sense either.
All that said you need to look at this for what it is. 50 pounds or dollars buys you another component. Like an AIO, SSD and so on. And if like most of the planet you are on a strict budget that's not to be sneezed at. And, I would imagine, is why the 7700XT has more users on Steam.
Let's also hope AMD offer a game with the GPUs as they often do too. Which again makes a huge difference.
