WYP
News Guru
Pricing, specifications, IPC improvements and more.
Read more about AMD's Ryzen 3rd Generation processors.
Gotta say it though, even though they are impressive numbers, they aren’t as impressive as the intital leaks that occured... With the 3700X rumored to have had an 5GHz boost.
Although, 4.4GHz boost on an 8c/16t CPU at 65W TDP? That’s impressive!
Weren't those AdoredTV Leaks disproven very quickly? The problem was that fanboys kept spreading them.
No idea, considering for example that Joker on Youtube mentioned them in a video. Though he did say to take the numbers with a grain of salt.
The 16 core is confirmed but it probably won't be revealed until E3 on June 10th
Guessing the early "leaks" of a 16 core AM4 part were false then considering it wasn't mentioned.
As far as the Ryzen 3700X VS Intel 9700K comparison goes, it is worth remembering that the i7-9700K costs more than AMD's $319 price point and consumes more power.
Fair means different things to different people. If AMD could have chosen Intel's best 65W processor for their comparison if they wanted. It really depends on what you are trying to compare. Both CPUs are similarly priced, so that's what AMD compared.
I mean a Cinebench run on a 8c 8t Intel CPU (9700K) up against a 8c 16t (3700x) AMD cpu and then act's surprised that it's faster?
Pretty sure AMD compare to parts in the same rough price range or above to make them fair, rather than matching selected bits of spec lists.
