AMD Releases their Radeon Software 16.9.1 Driver
Its about time someone got those dual GPU profiles out for Dota... I mean you would unlikely need more than a single GPU to run the game in the first place, but if you were to have SLI on then you these annoying as frame dips etc... My 980m's are not able to run DOTA 2 with SLI on, have to restart and turn it off b4 I play zzz
Now if only Vendors could update there software as frequently as AMD so there stuff doesn't slow down systems.. *looking at you Asus and MSI*
TBH they are pretty much all the same. Personally I find Lenevo to be the worst culprit for their consumer line.
Idk what you're talking about.. I was talking about Afterburner, GPU Tweak, etc. Since they take forever to update. Heck you can't even find GPU Tweak 2 online
