AMD Brings ATI Overdrive Auto-tune to Catalyst v9.4
On every single tech site I've read this on, it mentions new over drive feature called auto tune? I'm pretty sure it's been there for a long time
More of an update to the auto-tune...it now does a color screen test to stress the GPU included with an AMD logo which by the looks of it was edited out of a white document
Ya so How long exactly does AUTO TUne take:? I have AMD 955 8 GB DDR3 @1600 a Raptor Drive and of course 1 -4870 at 1 GB .. so far this Auto tune has been running for over 90 min with the occasional High speed card fan sound.
Any thoughts? Ahh ill just wait 1 more hour then im canceling
I strongly stand by overclocking the CPU via BIOS but in my experience, AMD Overdrive is definitely the best software overclocking tool that I've used. Very stable and I was able to carry out all adjustments (within reason) without any lock-up's. Further, the auto overclock utility worked very well. It didn't get the CPU anywhere near the max in BIOS but it's great for those that want a hassle free performance boost without learning a thing.
Expanding on autotune with AMD overdrive to the graphcis cards along with the latest Catalyst drivers is a very good move :)
It sounds like a good thing to get u to that solid oc position, then feeling brave u can drop into the bios and go slowly further - no ?
You cancel it man LOL. Run it for say 10mins and it's fine. You have to cancel it and if anything goes wrong you fix it :D.
my E-mail to Gskill W/product feedback Read it BACKWARDS
Okay so I went into BIOS changed the DRAM voltage to 1.8 and 1.7 (as requested by GSKILL support) Changed the DRAM freq to 1600 got BSOD=blu scrn o' death ,;Any suggestions on exactly what i need to change in the BIOS so i can run @ 1600freq ??
I have an AMD 955 3.2GHZ
PSU= OCZ 700Watt atx12V
4g (2x4) F3-10666CL9D-4GBNQ
MOBO= Asus M4A78T-E
ATI RadeonHD 4870 1GB - not SLi
To:
Subject: RE: 4GB stick
Date: Tue, 26 May 2009 15:04:12 -0700
Dear customer
Sorry we misunderstand your question. We don’t have DDR3 1333 4x4GB at this time.
Thank you
GSKILL SUPPORT
Sent: Tuesday, May 26, 2009 10:02 AM
To: G.SKILL USA SUPPORT
Subject: Re: 4GB stick
Thanks for the response , Although you didn't answer my question, Please Re-read my original Question Below. Thank you
Sent: Tuesday, May 26, 2009 10:03 AM
To:
Dear customer
F3-10666CL9D-4GBNQ is ok to run on Asus M4A78T-E motherboard but we can only guarantee 1 set to run at stock speed. If you are planning to run 2 sets 8GB, you might need to increase the voltage of memory to 1.6v to 1.7v and increase the voltage of NB.
Thank you
GSKILL SUPPORT
Sent: Monday, May 25, 2009 2:22 PM
To: ustech@gskill.com
Subject: 4GB stick
will you guys or anyone for that matter make a (4GB) stick for an Asus M4A78T-E MOBO?
specs id like are:
240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory
I recently purchased {F3-10666CL9D-4GBNQ } However my MOBO -- { M4A78T-E } supports up to, 16 GB but I cant find any 4 x 4 RAM; with these speeds.. can you suggest anything??
Rob
