thecompjedi
hi guys, just built my new rig and started to look at cpu overclocking. i have an AMD fx 8120 on a asrock 990fx extreme 3 motherboard being cooled by a corsair h60. i have managed to overclock from the standard 3.1 ghz clock to 4.1 ghz. this seems to be fairly stable, with decent temps at around 32 degrees. i know that to go higher i need to change the voltage but when i do so and then try to go to 4.2 my system does not boot so i try again with a slightly higher voltage and still no luck. i have heard of others with this setup achieving 4.6 ghz. does anyone have any suggestions as to what could be causing the boot failure? thanks in advance guys.
