AM3 Socket PC Help
siravarice
Had a root around myself and found I could build a new system really cheap. It would either be for me or for my girlfriend (I will take the better one obviously).
I already have RAM, HDD's and a power supply and a case.
Can people find stuff cheaper than I can?
I found:
£77.12 - AMD Athlon 2 X4 @ 2.6GHz
£65 - Gigabyte GA-MA770Y-UD3P
Optional:
£58 - OCZ Platinum (2x2GB)
Apparently the base Athlon X4 is faster than the Q8200 which is what I already have. If I save a little I would get a Phenom X4 instead.
Suggestions?
it alright! I fixed her computer, not sure if it was the ram of the slot the ram sits in, when i took her ram and swapped it for mine, my computer still ran fine and hers now runs fine too!. I gave her one of my 2gb sticks and took her two 1gb sticks. Thanks for the help though, still might think of building one as a HT system.
