Airflow: Which HD should I remove?
discy
Which HD should I remove for better airflow? 1 or 2? other tips are also appreciated.
The graphics card is Asus 6950 DirectCUII
i have also noticed that you are missing 1 or 2 PCI plates from the back of the chassis. this is ruining your airflow
if you can, get a 5.25" to 3.5" adapter, and move both your HDD's to your 5.25" bay.
then get a couple of blank expansion plates to cover up the gap.
