Dawelio
Active member
Heya guys,
So I’m wondering if anyone in here could recommend a solid 240 AIO that doesn’t have very long tubes and which are very flexible.
I’m thinking of getting the NCASE M1 and also the Fractal Design Celsius S24 Blackout. Due to it’s possibility to connect the fans directly on the radiator itself, rather than to a splitter on the block. Hence reducing cable clutter/management inside the tiny case.
Also considering the Noctua NF-A12x25 fans... Not sure how much better these are in comparison to for example Corsair ML fans?.
I’m using an Ryzen 7 3700X by the way.
Just asking for thoughts here and if you may have any recommendations?...
Thanks,
Dawelio
Thanks,
Dawelio
