meowwentthedino
Hey guys i'm looking to build an all in one monitor for my computer if possible could anyone recommend a good monitor panel and all monitor to use inside a computer case preferably around 13 inches as that is all that will fit inside the side of my pc case i have had a lot on ebay although i cannot seem to get any good decent results as most panels are too large and all out of budget if possible can you keep monitor panel under £50 and control board under £30 thank you very much dave
