Eddie long
Member
As a newbie to this who has enjoyed building my first rig , even though i have made a few mistakes , i decided over the last months to try and do a small overclock on my cpu.
After watching a couple of examples and reading articles on the web and oc3d , including Tom's on undervolting to start with , by just concentrating on core voltage , i had it down to 1.09v , ran occt in avx linpac mode and passed ok , then i tried cinebench , i had a slight stutter , so i increased after several attempts to 1.125v , and it run smoothly this time .
Now for the problem , i retested occt in avx/linpac all ok , so time to try using all logical cores , this part either comes up with an error , or it will freeze up , am i missing something , or just being thick,
I have reset cmos , and left as this , I've also loaded asus default setting and run again , although default only runs cpu up to 3.5 ghz and ram on 2133.
I'm using occt 4.5.1 ,30min run time , automatic setting , 90 percent memory use , i also try reducing memory use to 25 percent , made little or no difference ' If any can shed any light on what i am doing wrong would be helpful.
Cpu in use is i7-6950x with 32gb g.skill trident z 3200 mhz
