I completed my first build a couple of months ago based on some excellent advice received on this here forum. Please see my signature for rig details.
I've overclocked my CPU and GPU to levels that I am happy with, and I now want to put together a custom water loop. I'm not undertaking this loop in order to overclock further (my temps are fine with the H100i and Windforce card), I'm really doing it for the hell of it, although I will no doubt tweak the overclocks when I get the loop up and running.
I've read all the beginners information, and I'm now ready for some human interaction if you guys would be so kind...
First off, I don't have a budget in mind. I am happy to buy parts as and when funds are available. What I would say is that I would prefer to spend 6 months putting together a decent system, as opposed to rushing in and putting together a low end system that I will regret.
So, I have a particular requirement that you guys might blow out the water straight off the bat (see what I did there
). I don't want to fill my current rig with the water cooling kit, all I want in there are the water blocks and the tubing. Therefore, I want the rest of the kit to sit in an external enclosure. It will sit side by side with my rig, and I want it to look good.
Am I kidding myself on? If not, could anyone reply with an example of what kind of external enclosure / set-up would meet my "spec"?
I'm not looking to be spoon fed the entire build here. If someone can point me in the right direction I'll hit the books so to speak and update you on plans as they progress.
Cheers, and thanks in advance for any advice to follow.
