advice on a build, post 2 haha
i7OCNZ
Posting in the right area i hope
P8Z68-V/GEN3 - $246.39
Intel Sandy Bridge Quad-Core I52500K - $255
Asus GF GTX 560 DCII - $277
Seagate BARRACUDA 1TB SATA 3.5" 7200RPM 64MB - $118.77
LG 24x Internal DVD Drive SATA OEM - $27.84
Corsair 8GB (2x4GB) DDR3 1600MHz CL9 - $73.78
Thermaltake Lite Power 600w - $80
PHILIPS 22" 220S2SB LCD MON - $217
COOLER MASTER Storm ENFORCER - $146
COOLER MASTER HYPER 212 EVO COOLER $46
What you guys think. i like the Enforcer!! feedback plz
spending 80$ on psu and 277$ on gpu?
it's unfair for your rig!
don't forget that psu is the heart of your system.
I would change it with sth a little bigger and surely more reliable.
I am with elder_scrol on this one, Thermaltake PSU's are in the same boat as OCZ's to me atleast, I would look at Corsair. They have a great track record and they have some more economical solutions but at the same quality as the higher priced ones.
if u can't stress ur budget so much I would recommend an xfx 650 psu.
imo it's very reliable and has seasonic guts, if u know what I mean
I look at it like this. I would spend about 60% of what I spend on CPU or GPU for a PSU. The old saying "you get what you pay for" applies here. But there are other options out there.
I think you will like it alot better, you will be able to pick and choose what cables you want, and in the future you will be able to change them out for indivually braided cables for that bling bling effect.
Personally I wouldnt know havent taken had any experience with it. You should check to see if Tom did a review on it on the OC3D channel on youtube. If he doesnt have a video review for it check all the retailer sites like Newegg and Performance PC's for costumer reviews
i use a silverpower 650w psu to power a overclocked 2500k and a overclocked gtx580 and it does this with ease a good power supply is a must and the amps on the 12volt rail are also important also silverpower psu's have seasonic guts so are good quality powersupplys at a good price
@JP88, buffering now, only just started watchn his channel, its definetly one of the best hahaha gotta get heaps of perspective tho
just a quick question, will the Corsair 650W AX-650 ATX, work with the Gigabyte 560ti OC, since it requires 2 6 pin externals? sorry for the dumb questions haha
The AX650w accomidates both 8 pin and 6 pin, basically it has a 6pin with a 2 pin on the pci express plugs so you can run either. And it comes with 4 of those cables.
Cheers bro, i will prolly be buyin this whole rig come monday!
