adaptec 5805
blitz
hi im looking for some help with my adaptec 5805
fist my pc =
asus rampage 2 extreme
intel i7-965
xfx hd 5970 black edition
Corsair Dominator GT 2000mhz
ASUS XONAR XENSE 7.1 Sound Card
ok il give u the full story. i have 3 pci expess in the top 1 there my gpu in the 2 there nothing and in the 3 my sound card.
so i put my raid card in the 2 pci slot and when i started the pc up it bios hangs. tryed fiding with the bios nothing. I swoped
my sound card with the raid card the pc boots and im at my desktop boot my raid card is not working. so i swop my gpu and raid card the
same thing it boot in but duz not work. so i have a bit of a google about and come to the conclusion that it a blank card ther no bios on it
so i got the up to date bios and folow the instructions to install the bios. and i cant install it haha.
ok you have to put all the file on to a memory stick and booted to the stick and it opens win95 or 98. and opens me to a command prompt
and then you type AFU.EXE to install the bios and it says no known controllers detected. quitting. lol . so i do some more googleing and get
no were. iv been emailing adaptec and thay want £50 off me so i thort id ask hir to see if any 1 can help any advice will be gratefully received.
ps if i cant fix it haz any 1 got a hammar i can borrow!!! haha thx
Sounds like the adaptec card may be dead. Have you ever had it work properly? I have the same card, and it works fine in both my sabertooth X58 and X58 Classified. If the controller isn't being detected, go back to the store you bought it from to test it properly.
unfortunately it's a ebay and i can't return it and iv not had it working yet lol do you want to swop haha
can any1 shed any light on it.
Diablo can you plz tell me how you installed your bios and car thx m8
