Acer monitor get a little lag
matrex_a1990
hello all
i have intel i7 4770k ,amd r9 280x gigabyte, gigabyte z87x-ud5h, 16gb ram
i just got my new monitor Acer V236HLbd its a full hd 1920 * 1080 5ms IPS 60 hz
its have a wonderful color and depth but i notice a little lag when i watch movie
i try it on dark night rises 1080p 11Gb !! using k lite codec , in my previous monitor it was working fine
the monitor connect with DVI-D (single link)
i try overclock my monitor 66 Hz the maximum monitor could have
so this lag from the monitor speed (IPS plate) or i should use dual DVI cable or what
thanks for your attention ;)
Agree with TTL and SuB, you don't need K-Lite anymore, that hasn't been needed since XP days. Use like Sub said Media Player Home Cinema or VLC or MPCStar, the first 2 have great on the fly tweeks.
Yeah it's just not required anymore. They cause more problems than they solve :)
Glad you got it sorted :)
