If you buy the ABit MB and a Winchester CPU and find that it wont boot up coz you need to flash the BIOS here are the options..
1.. get a 130nm Chip and flash the BIOS.....
if thats not an option then you can always send the BIOS chip back to Abit UK and they will send you another one that has the latest bios version on.. (I have the address and details if you want...)
or you can HOT Flash your bios.... WOW...
For thoes that have no idea what that means.. Basically you need 2 PC's with the same BIOS chip (please check the internet for full instructions on this). You boot up the one that works with a boot disk and flash software and then while the PC is on take out that BIOS chip and put the one you want to flash and force a bios flash..
Check this guide. Read all the guide first
http://www.rojakpot.com/default.aspx?location=3&var1=62&var2=0
Thats what I did and after 3 attempts and some change of underwear it worked and I have a Abit MB with a winchester CPU working.. hehe
Warning.... HOT Flashing is not recommended if you have the following conditions. Heart Problems, High Blood Pressure or any nervous disposition.... If in doubt please consult your doctor for further advice.
