A64 and Half Multi's
  • Thread starter Thread starter JN
  • Start date Start date
JN
I remember hearing a while back that AMD64's and half multi's were bad.
As i recall it had some negative effect on memory bandwidth (correct me if i'm wrong).
However, i was wondering if anybody knew if this affected the Venices & Diego's - as i remember it being a problem on previous memory controllers?
I've just run some tests and using Sandra, half multi's do not hit my memory bandwidth performance...but is there anything else i should be looking for...
Wirelessly posted (Nextel - Motorola i860: MOT-A-1C/00.06 UP.Browser/7.0.0.2.257 (GUI) MMP/2.0 UP.Link/5.1.2.12)
Jim as i recall this problem was only apparent on the s754 platform as far as i remember. Someone ply correct me if im wrong. May have only been the dtrs too but im pretty sure it was a socket wide problem.
no sir , nothing has been fixed . The problem exists for both sockets as of now.
Any half multiplier runs a divider on your ram.
so with an 8.5x300 cpu fsb , ur memory should be around 250 mhz or so . ( i cant remember which ratio it runs though ) .
this is becoz of the mem controller being on the cpu die.
so as long as u have the mem controller on the cpu , half multis are bad news.
neither venice nor sandiego have this problem fixed as well .
|3ourne comes in and clears it all up :)
Thanks mate...more reps for you!! :D
