Hi guys.
I'm currently running a 4690k and an MSI GTX 970 on a 1080 G-sync screen. Not really looking to change the panel at the moment, but am thinking about changing the GPU. I think a 980ti would be overkill for 1080, but would the change to a 980 be worth it. Or should I just wait for the next NVIDIA GPU with HBM, I think it's code named "volta", and then upgrade the panel to an ultra wide, IPS G-Sync one?
Any honest, logical, advice would be great.
Cheers.
Cheers.
