Hi guys!
I was working on my 990x OC, and i got to the point where i am stable on 4.5ghz, 1.375v in bios, 1.363v in idle (cpu-z), and 1.330v in load (cpu-z), 50% loadline calibration, but im only stable in prime95 small fft, and games run without problems (mostly bfbc 2). when i do blend, it is reporting rounding errors, never BSODs. I flashed to bios 0003, and i can modify tRL values now, but i dont know where to start. whatever i try, i get errors. i have g skill trident 2000mhz 9-9-9-24 kit, and i run it at 1804mhz 9-9-9-24-1n with uncore of 3608, cpu at 180x25. PLEASE HELP. I tried raising qpi/dram voltage and ram voltage, no use. temps dont get above 72c. I assumed that my cpu is stable at those voltages, and that the problem is something else (probably the memory), am I wrong? I feel like im playing bingo with this thing...it even happened to me once that i was running blend stable for like 2 hours, shut down, and in the morning, started the pc and again not stable for blend. I dont get BSODs, i get rounding errors.
