980ti drivers
JAMIE1000
Just got the Asus Matrix GTX980 Ti card did have 980ti ref will after reinstall drivers or will it be all good just plug new one in.
/.the Jamie
You won't need to reinstall the drivers unless there's a newer version available than what you have already.
Just check to see if there is an updated version of the GPU drivers and if there is upgrade but remember to rum DDU to uninstalled the old ones first.
