Vipermk2
I have a Rampage V edition 10 with 2 M.2 drives connected.
1 x 960 Pro attached to the M.2 slot on the mobo partitioned into 2, one for system and one for games.
1 x 950 Pro attached to the PCie 8_4 slot via an adapter which there seems to be no problem with at all. See image below.
When it comes to the 960 Pro its a different matter, the reading seem to be all over the place especially the system drive which drops as low as 1875 on sequencial read (which i didnt capture) but the Samsung magician gives very much different results even when Crystal Disk Mark shows relatively high readings but not as high as the 2nd partition.
System Drive:
The D drive is what it should be:
The only reason I noticed was because I tested my rig at User Benchmark after ugrading quite a few components and noticed the 960 Pro was performing badly
Any ideas why this is, the NVMe driver is up to date and so is the drive firmware.
System Drive:
