92 MM Fan Suggestions Please
leejc73
Hi Guys,
This is going to go against the ideals of 95% of you but I need a couple of hard blowing 92MM Fans.
Thing is noise is NOT a factor, I'm looking for highest static pressures/flow rates possible regardless of noise, I've got a HP Workstation (XW6200) which is being used as a server and it's running dual Xeon's. I want to get the maximum life out of the hardware possible and at the minute one of the fans is failing allowing the CPU to creep up to 60 degrees.
So do your worst, don't care about noise, and price would be have to weighed against system downtime for component failure.
Cheers
Lee
