Nicholas Spawn
I as planning on doing something similar as this
All radiators xspc ax series
Top Radiator push/pull 480mm
The bottom 480mm Radiator has push, the 240 has pull leaving space in the middle for running the pipes
2 seprate loops
series parallel w/ dual mcp355 gpu loop 4x 780ti
series d5 vario mobo loop
All Rigid tubing
Do you think this will be sufficent for heat disipation?
Mobo is wifi bk
Sorry, im new to the forums, and this is my first post
2 seprate loops
All Rigid tubing
Mobo is wifi bk
