Rastalovich
Actual zak, I probably would oc it, and tell them.
Now basing it on some of the examples of the good cooling methods, I'm certainly not going to suggest something like taking a Q6600 to 3.6 and handing it over "cos it worked ok on the bench for an evening".
However, taking the Q6600 as an example, I'd definitely consider a timid oc, keep the memory at around spd/non-oc'd levels so there's no fear of it acting up. And hey, they have an added boast of a mildly oc'd pc.
(same with the gfxcard tbh. like if u know the card will do 725mhz from a stock 650mhz - put it at 675 or something - and tell them. similar deal, don't consider pushing the memory)
I do understand the requirement for it to no act-up tho, so it would depend on the components u settle on. And if u build it urself - consider very strongly creating a partition to store an image of the build, that way if windows does act-up, reapplying an image in minutes also impresses.
Another thing u could consider, understanding that I don't fully know what build u got, but how about offering them ur rig and buying new urself ? Obviously u know how stable ur system is under conditions - but again, I'm not fully clued on ur entire setup so I could be selling u short without knowing
