Yeah, it is colder in West Yorks today aint itDazboots said:my god just hit -72 on my mach 2 GT
in motherboard monitor its showing -25
now i think -25 on a abit -ic7-max 3 is good
because the temp r a bit higher than they should.
whats ppl temps here in motherboard monitor on a abit -ic7-max 3.
Did you post piccies of your build as I've same mobo as U and I know some folks have had moisture issues? Di U use conf coat or grease or anything?Dazboots said:contact must be good running 24/7
3.2 overclocked to 4249 mhz 1.82 volts extreme edition.
not going to strip it doing well.
no condensation in 3 weeks now.
looks like i have done a good job installing it.
I've not even had my mobo out of box cos I'm waiting 4 my GT and modded case from Phil! So literal answer would be about 20°C today! I'll post once the hardware all arrives, assuming I don't mess upDazboots said:not using anything
just 1 lot of seal string
and 2 extra washers on each head screws.
what temp r u getting in motherboard monitor.
on ur ic7-max 3
i get -105c. reaches that temp really quick at idleDazboots said:whats ppl temps here in motherboard monitor on a abit -ic7-max 3.
name='slim' said:Dazboots did you have to modify the cpu kit for the IC7-MAX3 at all? I've had a few problems getting it to sit flush (contact problems).
