R robump New member Jun 24, 2007 #1 Should i use the auxillary power connector on my evga 680i for the graphics. I am going to be running a 8800gts 640mb version. Thanks for your help. Rob
F FarFarAway New member Jun 24, 2007 #2 If you can I would. It's mainly for SLI but the boards have a bit cleaner power when it's put in
R robump New member Jun 24, 2007 #3 Thanks for your super quick response. I will add it int hen, also on my new power supply a osz gamer xtrme, there are 2 connectors labled cpu 1 and cpu 2. I presume i just add them together and put them into the the auxillary socket. Thanks Rob
F FarFarAway New member Jun 24, 2007 #4 Well umm those should go into the ATX 12v socket, otherwise the motherboard won't work! The SLI power connector is near the bottom of the board and has a molex connector
R robump New member Jun 24, 2007 #5 so i deffinatly need to connect the other 8 pin one. Thanks for your help kempez. Rob
