6800GT O/C Advice
Blyths
Hi all,
I have a 6800GT which i have managed to OC to 410/1101.
I have a Zalman VF700-cu cooler attached.
My Question is do you OC the 2D settings as well? As i have ever only OC the 3D settings.
Many Thanks
Blyths
Give it go and see.
To get my 6800GT scores I did overclock both clocks (450/1250), your ram and will overclock higher if:
1) Using Rivatuner you disable to clock test
2) Use some ramsinks in them to draw heat away from them
3) Use a 2nd fan to blow cooler air over them.
4) Remove any PCI covers on your case to allow the hot air to escape quicker.
Hope this helps.
Cheers
Mav
