5.25 bay fan controller sugguestions
NZXT Sentry have slides as does the Sentry Mix here a comparison of them from Newegg
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100006519%2050002120%2040000011&IsNodeId=1&Manufactory=2120&bop=And&SpeTabStoreType=1&CompareItemList=11|11-992-007^11-992-007-TS%2C11-992-009^11-992-009-TS
Dont get the nzxt sentry SEN-001LX, the display is horrible..... You can see all the icons that are not lit up like some old 80s arcade slot machine..
Yea personally I'm going to get a lamptron touch for my next build. I've heard good things. 6 channels upto 30W per channel might be overkill for what you need. reads RPMs, temp sensors for each channel. Has a manual and basic automatic temperature control. Touchscreen is the old style pressure sensitive which means it isn't great (not that you will be using it much) but also means it's easy to use a pen or stylus with.
Review
Quite pricey unless you want to make use of all those powerful channels though.
Scythe KM02-BK
This may be worth a look at 12w per channel which isn't as good as the Lamptron however will show the fan RPM and temperature of 4 thermal probes which can be placed around your case and at reasonable price.
I have a lamptron touch , was also considering a Scythe Kaze Server , but like you, didn't want the knobs.
